Date/Time: Sat, 07 Nov 2026 11:32:48 +0000
Saving Text Settings in Graphics Settings Preset [Feature Request]
View Count: 19
| [2026-11-07 09:01:30] |
| Deenius - Posts: 168 |
I’m creating a Sierra Chart configuration file for my community so members won’t have to go through a complicated, time-consuming process to set up their platform. Basically, they’ll just copy this file into their Sierra Chart folder (overwriting the original Sierra4.config file) and will be able to start working right away. However, while creating color schemes, I ran into a problem. When I changed my text settings, I discovered that Sierra Chart couldn’t save them under the Graphic Settings preset. This surprised me quite a bit, since software that allows you to create themes usually saves both color settings and text formatting. As you know, different people have different preferences, so I’d like to give them a choice of themes with varying text styles and sizes. For example, older people generally prefer larger, bolder text, so I’d like to accommodate that in some of the presets. Could you please make it so that text settings are saved within the Graphics Settings preset? Thank you. Date Time Of Last Edit: 2026-11-07 09:03:27
