Date/Time: Fri, 06 Nov 2026 13:12:22 +0000
[Programming Help] - Cannot compile Custom Studies
View Count: 6
| [2026-11-06 12:46:07] |
| jsob - Posts: 41 |
I am not a software engineer. I have written and successfully compiled my study for years. However, this morning I'm encountering build failures following an update to my system of version 2982. When I select the Build option: "Build with Visual C++ - Release" I get the following ===== -- Starting build of Custom Studies Source files: test.cpp. -- 07:32:21 C:\WINDOWS\system32\cmd.exe /C "C:\SierraChart\ACS_Source\VisualCCompile.Bat" C:\SierraChart\ACS_Source>call "" amd64 '""' is not recognized as an internal or external command, operable program or batch file. C:\SierraChart\ACS_Source>cl /Zc:wchar_t /GS /GL /W3 /O2 /Zc:inline /D "NDEBUG" /D "_WINDOWS" /D "_USRDLL" /D "_WINDLL" /Oy /Gd /Gy /Oi /GR- /GF /Ot /fp:precise /MT /std:c++17 /LD /EHa /WX- /nologo "C:\SierraChart\ACS_Source\test.cpp" /link "Gdi32.lib" "User32.lib" /DLL /DYNAMICBASE /INCREMENTAL:NO /OPT:REF /OPT:ICF /MACHINE:X64 /OUT:"C:\SierraChart\Data\test_64.dll" 'cl' is not recognized as an internal or external command, operable program or batch file. -- End of Build -- 07:32:22 ========= when I select "Remote Build" the fail message is: -- Starting remote build of Custom Studies Source files: test.cpp. 64-bit -- 07:36:21 Allow time for the server to compile the files and build the DLL. Server: https://build.sierrachart.com The remote build is complete. The build failed. test.cpp:3:10: fatal error: scstudyfunctions.h: No such file or directory 3 | #include "scstudyfunctions.h" | ^~~~~~~~~~~~~~~~~~~~ compilation terminated. Failed to generate the DLL file. -- End of Build -- 07:36:23 |
