Date/Time: Thu, 05 Nov 2026 02:24:53 +0000
Feature request: Multi-instance syncing
View Count: 5
[2026-11-05 01:49:54]
User806682 - Posts: 26
One of my frustrations after splitting up my chartbook to use two separate instances in an effort to improve performance is that I can no longer sync the different options available when linking charts under Chart Settings >> Linking, as well as having the global crosshair under Tools >> Global Cursor On.
If possible, could you consider making it possible to sync these two features across different sierra instances?
I was thinking about a global setting that can be toggled to turn these on/off.
