Date/Time: Sun, 01 Nov 2026 20:05:15 +0000
Encountered invalid field code (0) while reading Chartbook file
View Count: 1603
| [2014-11-10 16:42:10] |
| User19570 - Posts: 3 |
Hello, i have always the same message when i try to open my charts Encountered invalid field code (0) while reading Chartbook file: C:\SierraChart\Data\DeltaNumberBarsOnP&F_5TickReversal.cht | 2014-11-10 17:08:41 * Thank you for your future answer. |
| [2014-11-10 16:49:15] |
We are looking into this problem.
| [2014-11-10 18:11:26] |
| Al SC Developer - Posts: 434 |
Can you attach the chartbook file here so we can try loading it? Edit: Please disregard, as this should be addressed in ver 1210. Date Time Of Last Edit: 2014-11-10 19:44:53
| [2014-11-10 20:21:27] |
hello Ok i attach my file |
| [2014-11-10 22:16:53] |
We have the problem solved. We are releasing 1210 now to resolve the issue.
| [2014-11-11 13:20:32] |
Thank you for your job ! It's OK now.
