Date/Time: Wed, 04 Nov 2026 17:17:46 +0000
Hoe To Remove a Dom attached on a chart
View Count: 27
| [2026-11-04 13:55:34] |
| User241301 - Posts: 1 |
Hi, please help me—I'm going crazy. How do I remove the Time and Sales element attached to the chart?
Date Time Of Last Edit: 2026-11-04 14:09:47
| [2026-11-04 15:27:54] |
| John - SC Support - Posts: 48420 |
Select the menu item (between Quote and Trade) for "TS >> Settings >> Attached to Owner Chart >> None". Then the window will be separated from the chart and you can move/close it as desired. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
