Date/Time: Tue, 03 Nov 2026 16:43:50 +0000
Custom Divergence Study: Numbers Bars Delta and Candle Sticks
View Count: 41
[2026-11-03 13:20:45]
User862138 - Posts: 38
I am using Sierra Charts for trading. I want to develop a colour round solid point/triangle marker. The marker must be displayed on the Numbers Bars chart (Region 1). When the candle stick is green, but Delta is negative, there must be a red round (circle) solid marker displayed. When there is a red candle, but Delta is positive, there must be a green round (circle) solid marker displayed. The triangles must be displayed just above the relevant candlestick bar (Region 1 of the Numbers Bars chart).
I got the following info, but I can not get a round marker to display:
- When I display a "Colour Bar based on Alert Conditions" for a RED display, I typed in: =AND(C > 0,ID: 300,SG1 < 0) and vice versa for a GREEN display.
I am not sure if the SG and ID formats are right.
Can you assist?
Kind regards
Deon
[2026-11-03 14:55:03]
John - SC Support - Posts: 48402
this part does not make sense:
Refer to the following for how to reference a study and subgraph in an alert:
Study/Chart Alerts And Scanning: Referencing Other Studies on the Chart
[2026-11-03 15:04:49]
Hi John,
It is the code when you click on Analysis and have chosen Numbers Bars - at the end of that sentence is an ID .....
Deon
[2026-11-03 15:39:31]
What exactly are you wanting to do? What are you trying to alert on?
[2026-11-03 15:44:10]
When the candle stick in Numbers Bars is green, but Delta Iin Numbers Bars Calculated Values) is negative, there must be a red round (circle) solid marker/dot displayed. When there is a red candle, but Delta is positive, there must be a green round (circle) solid marker displayed. The triangles must be displayed just above the relevant candlestick bar (Region 1 of the Numbers Bars chart).
