Date/Time: Mon, 02 Nov 2026 20:54:18 +0000
How to detach and attached TS window.
View Count: 8
| [2026-11-02 19:55:41] |
| rondawes - Posts: 54 |
I thought I was somewhat knowledgeable about SC and it's ways but this has me stumped. I created a TS window, set its width and columns that I wanted. I attached it to a chart. When it attached it became much wider than I had set it up to be. I'm guessing that it's now wide enough for all the columns, not just the ones I selected. How do I change the width of the TS portion while it's attached? I can change the column widths, just not the width of the TS window. I can't grab the leftmost column left edge. Also, I cannot figure out how to detach the TS window from the chart. Thanks |
