Date/Time: Mon, 02 Nov 2026 16:12:31 +0000
[BUG] Broken checkboxes rendering after latest Windows upgrade
View Count: 21
[2026-11-02 15:14:33]
maxima120 - Posts: 176
I have 2957 version and a older one running. Today all checkboxes were broken across all the instances and all the UI elements. See the picture.
Worked fine on Friday.
On the weekend Win11 latest updates were installed.
On Monday - broken SC UI
imagesc-broken-checkboxes.png / V - Attached On 2026-11-02 15:13:23 UTC - Size: 10.49 KB - 7 views
[2026-11-02 15:40:05]
John - SC Support - Posts: 48386
So all the checkboxes within Sierra Chart are showing that way?
Are they actually working properly, can you enable/disable the option and does it function properly in the selected state?
Have you rebooted your computer to see if that resolves the issue?
Those checkboxes are standard Windows options that we do not have control over. This is one of the reasons we are moving away from these Microsoft items to our own. Most likely there is nothing we can do about this, but we are curious about the above.
