Date/Time: Sat, 31 Oct 2026 02:19:07 +0000
Trading DOM - Current Traded Ask Vol Bid Vol Difference
View Count: 10
[2026-10-30 23:51:06]
UTkRussell - Posts: 31
John,
Can you take a look at the "Current Traded Ask Volume Bid Volume Difference" column on the Trading DOM? Specifically the positive vs negative text/volume bar colors. I would have expected all the blue bars to have light blue text, similarly for red volume bars with pink text (per my global color settings). Seeing some red volume bars with blue text and vice versa. Not sure whether the volume bar or the text color is actually correct.
FYI, using 4 tick grouping on the NQ.
imageSC - DOM Delta Columns.png / V - Attached On 2026-10-30 23:42:32 UTC - Size: 56.13 KB - 4 views
