Date/Time: Fri, 30 Oct 2026 13:16:24 +0000
[Feature Request] "To Next Session Start" and "To Next Time" Options for Replay Tool
View Count: 12
| [2026-10-30 10:54:25] |
| Deenius - Posts: 165 |
Hello, Would it be possible to add “To Next Session Start” and “To Next Time” jump options to the replay tool? Currently, the replay tool can jump in several ways, but unfortunately, none of them allow for truly convenient, quick navigation between individual sessions. For example, if at any point I want to move to the start of the next regular session, I have to either “click my way” there using the “To Next Bar” option or calculate the time jump and use “By Time.” That’s quite unnecessarily tedious. With a “To Next Session Start” option, this could be done with just one click. I believe this shouldn’t be difficult to implement, since every symbol has a clearly defined Session Start Time. Of course, different traders trade different sessions, so the “To Next Session Start” option isn’t enough. We also need a “To Next Time” option, which would allow us to jump to the start of the London, Asian, or even New York PM sessions. As the name suggests, this would simply involve specifying the time to which the Replay tool should jump. Technically speaking, only the second option could be added to the Replay tool, since it also allows jumping between the starts of regular sessions. However, if a user is backtesting other sessions in addition to the regular session (such as the London session), it’s better to have the “To Next Start Time” option available as well, since this would prevent the need to constantly change the time in the time input field. Thank you for considering my suggestion. |
