Date/Time: Sun, 01 Nov 2026 20:03:01 +0000
cumalative delta
View Count: 1301
| [2014-11-10 13:26:52] |
| User15378 - Posts: 45 |
Hi there, i have my data services to 1 second as i prefer that one, just would like to know on that setting which cummalative delta is more accurate, cummalative delta up/down tick volume or cummalative delta volume? Thank you |
| [2014-11-10 17:15:35] |
The only accurate one would be Cumulative Delta-Volume.
