Date/Time: Wed, 28 Oct 2026 22:49:09 +0000
Issue with Font style selection for CountDown Timer study
View Count: 24
[2026-10-28 20:54:11]
moralSL - Posts: 1
I'm looking to have the CountDown Timer study inherit the exact font selected for Chart Text (Global) in Graphics Settings - Font. The study defaults and overrides to a bold or bold oblique/italic style even if a regular/normal font is chosen.
I have changed the study subgraph Width/Size to no avail. OpenGL toggle has no effect.
[2026-10-28 21:31:30]
John - SC Support - Posts: 48363
We see that this is fixed as a Bold Font.
Since it was a very easy change, we have updated the Countdown Timer to have an option for "Use Bold Font". You can set this to "No" to use the "Normal" (not bold) font.
This will be out with the next Pre-Release (v 2980).
[2026-10-28 21:36:35]
User719512 - Posts: 520
The source is in Studies2.cpp.
You could modify however you wish and build your own version.
SCSFExport scsf_CountDownTimer(SCStudyInterfaceRef sc)
  Tool.FontBold = true;
  Tool.FontSize = Subgraph_Countdown.LineWidth;
  Tool.FontFace = sc.GetChartTextFontFaceName();
