Date/Time: Wed, 28 Oct 2026 19:28:46 +0000
ATR value box?
View Count: 18
[2026-10-28 18:26:46]
User181655 - Posts: 63
Hi
Is there any way we can display the values of the ATR just as a figure on the 1min chart...which not only shows the current value but also of previous 1min bars?
Regards
[2026-10-28 18:29:47]
John - SC Support - Posts: 48355
You can display the current value of nearly any study using the "Text Display for Study" study. Refer to the following:
Text Display For Study
That same study has an Input for "Display Columns Back" which allows you to reference a previous bar. So to get the bar just before the current bar, you would enter a value of "1" in that field.
