Date/Time: Wed, 28 Oct 2026 13:59:38 +0000
Deterministic Safe Mode startup before automatic login
View Count: 14
[2026-10-28 13:02:42]
Richard Chinn - Posts: 36
We operate a separate Sierra Chart installation containing a registered startup chartbook with ACSIL custom studies.
For a controlled diagnostic session, we need to guarantee that no startup chartbook or custom study executes before an operator can select Safe Mode and disable Open Files on Startup.
The documented procedure requires canceling a pending automatic login and selecting these controls on the Login window.
Is there an officially supported method to establish both controls before the Sierra Chart executable begins its login/startup sequence?
If not, is there a supported procedure for preventing automatic login or chartbook loading without first starting the installation normally or manually editing Sierra4.config?
We need to preserve the existing installation configuration for evidence comparison and avoid custom-study execution during the diagnostic session.
Thanks,
Richard
