Date/Time: Sun, 01 Nov 2026 20:02:04 +0000
Problems after update
View Count: 1418
[2014-11-10 12:09:52]
User57072 - Posts: 49
After i updated to the newest version, i tried to open my chart book and this is the message i got.
Software version: 1205 | 2014-11-10 06:02:14
Usage end date: 2014-12-08 | 2014-11-10 06:02:14
Enabled for: Advanced Features. | 2014-11-10 06:02:14
Enabled for: Sierra Chart Historical Data Service. | 2014-11-10 06:02:14
Allow Support for Sierra Chart Data Feeds is enabled. | 2014-11-10 06:02:14
Active service: SC Historical Data | 2014-11-10 06:02:14
Time Zone: -06:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-11-10 06:02:14
2014-11-10 06:02:14 Local computer clock time | 2014-11-10 06:02:14
2014-11-10 12:02:14 GMT time | 2014-11-10 06:02:14
2014-11-10 06:02:14 Time zone adjusted time | 2014-11-10 06:02:14
Time difference to server time: 4 seconds. | 2014-11-10 06:02:14
Program path: C:\SierraChart\ | 2014-11-10 06:02:14
Data Files path: C:\SierraChart\Data\ | 2014-11-10 06:02:14
OS Version Number: 6.0 | 2014-11-10 06:02:14
Locale Information: C | 2014-11-10 06:02:14
Checking for new symbol settings for ddf | 2014-11-10 06:02:14
HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 88.198.13.175 | 2014-11-10 06:02:14
HTTP connection to www.sierrachart.com:80 (1288) | Connected. | 2014-11-10 06:02:14
Symbol settings are up-to-date for ddf | 2014-11-10 06:02:15
SC Historical Data | Connected. Historical Intraday data will be requested. | 2014-11-10 06:02:19
HTTP connection to www.sierrachart.com:80 (1288) | Closed. No error. | 2014-11-10 06:02:20
HTTP connection to www.sierrachart.com:80 (1288) | Shutdown and closed. | 2014-11-10 06:02:20
Encountered invalid field code (0) while reading Chartbook file: E:\Desktop\Chartbook2.cht | 2014-11-10 06:02:46 *
Encountered invalid field code (0) while reading Chartbook file: C:\SierraChart\Data\Chartbook2.cht | 2014-11-10 06:08:21 *
Encountered invalid field code (0) while reading Chartbook file: C:\SierraChart\Data\Chartbook5.cht | 2014-11-10 06:08:32 *
[2014-11-10 16:49:44]
We are looking into this problem now.
[2014-11-10 19:55:31]
We have discovered the problem. We are going to be releasing version 1210 in a couple of hours which will fix this.
