Date/Time: Tue, 27 Oct 2026 03:14:20 +0000
[Programming Help] - cannot get time in ATBB
View Count: 36
| [2026-10-27 00:17:20] |
| walt_IB - Posts: 7 |
I am attempting to debug and it looks the "sc.BaseDateTimeIn[sc.Index]" does not seem to work. I put a stop where "exitnow" is set and it never hits... int hour = 0; int minute = 0; int second = 0; bool exitNow; SCDateTime barTime = sc.BaseDateTimeIn[sc.Index]; barTime.GetTimeHMS(hour, minute, second); if (hour == 15 && minute >= 44 ) { exitNow = true;//never gets here } >> I've had the same issue running live... Date Time Of Last Edit: 2026-10-27 00:57:46
| [2026-10-27 01:22:54] |
| Sierra_Chart Engineering - Posts: 25290 |
What is the timeframe of an individual chart bar?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-10-27 01:23:06
| [2026-10-27 01:27:22] |
2 minute TF... >> I also tried slow replay and it also never sets the "exitNow"... My study has been working fine except for this... |
| [2026-10-27 02:56:24] |
| User719512 - Posts: 516 |
Add the Bar Numbering study to your chart, set Bar Index input to Yes. Locate a bar where your signal should fire and note its index. Add to your code something like: if (sc.Index == 100) // whatever this # should be { int hour = 0; int minute = 0; int second = 0; SCDateTime barTime = sc.BaseDateTimeIn[sc.Index]; barTime.GetTimeHMS(hour, minute, second); SCString msg; msg.Format("%d, %d %d %d", sc.Index, hour, minute, second); sc.AddMessageToLog(msg, 1); } ...or if you build locally, set a breakpoint and inspect your code and find the bug. |
