Date/Time: Sun, 01 Nov 2026 20:05:05 +0000
can't connect via FIX FXCM
View Count: 1684
[2014-11-10 06:07:26]
4646ed - Posts: 231
I got the FIX connection info from FXCM as you detailed in your help files (http://www.sierrachart.com/index.php?page=doc/FXCMTrading.php) but cannot connect: here's a copy of the log.
I've also sent the message log for analysis.
Date Time Of Last Edit: 2014-11-10 07:00:39
imageSC FXCM FIX connection Error Log.JPG / V - Attached On 2014-11-10 06:06:56 UTC - Size: 69.83 KB - 512 views
[2014-11-10 08:24:09]
Restart Sierra Chart. Do you get a System Notification message indicating your computer's clock is not set accurately?
If not, then there is a problem with the FXCM connection details you have entered in Global Settings >> Data/Trade Service Settings.
[2014-11-10 08:30:11]
4646ed - Posts: 231
The clock is fine, 0 seconds to server. If its the fxcm details then I would have to contact FXCM about that? Or should I send them to you and you try them?
[2014-11-10 08:55:24]
Send us the FXCM FIX connection details sent to you by FXCM. Send it through an Account Support Ticket and we will test them:
https://www.sierrachart.com/usercp.php?page=SupportTickets
Date Time Of Last Edit: 2014-11-10 08:55:41
[2014-11-10 11:38:22]
4646ed - Posts: 231
sent
[2014-11-11 01:46:04]
This has been reviewed and responded to by email and also the Account Support Ticket.
