Date/Time: Fri, 23 Oct 2026 16:23:37 +0000
Snap to Drawings
View Count: 14
[2026-10-23 15:21:27]
cfuture - Posts: 85
I have lines drawn from a reference chart being drawn in my entry chart yet when I want to use my retracement tool in the entry chart to snap to the line from my reference chart, I get nothing. Is there a setting or is there no function at all for this situation?
[2026-10-23 16:17:26]
John - SC Support - Posts: 48312
There is no option to "Snap To" another drawing. The only snapping options are to the Open, High, Low, or Close of a bar.
If you want to match up exactly, then after you have drawn the retracement, you can use the crosshairs to get the price value at a bar where you want the retracement to start and then adjust the Anchor point to be exactly where you want.
The anchors can be accessed/modified on the Chart Drawing Properties in the "Anchors" tab.
