Date/Time: Fri, 23 Oct 2026 00:14:50 +0000
Volume by Price - How to Hide Zero Values in Diagonal Delta Profile
View Count: 26
| [2026-10-22 19:35:21] |
| User658000 - Posts: 1 |
**Subject: Volume by Price – Hide zero values in Diagonal Dominant AskVol - BidVol display** Hello Sierra Chart Support, I am using the **Volume by Price** study to display a session profile on the right side of my Numbers Bars (Footprint) chart. My goal is to keep the native profile exactly as it is, including the colored bars and the diagonal delta values at each price level, but **hide only the numeric labels that are equal to 0**. My current settings include: - **Volume Bar Calculation Method:** Diagonal Dominant AskVol - BidVol (Numbers Bars) - **Bid Volume and Ask Volume Coloring Method:** Diagonal Dominant AskVol - BidVol Coloring (Numbers Bars) - **Display Volume in Bars:** Diagonal Dominant AskVol - BidVol (Numbers Bars) - **Ticks Per Volume Bar:** 1 - **Volume Text Threshold:** 1 I have already tried setting **Volume Text Threshold = 1**, but the zero labels are still displayed. My questions are: 1. Is there a native setting that hides only the zero values in this specific display mode? 2. If not, is there a way to suppress these zero labels using ACSIL while preserving the exact native Volume by Price calculations, bar colors, and positioning? 3. If this is currently unsupported, could you consider adding an option such as **Hide Zero Values** to the Volume by Price study? I do not want to hide the entire price level or change the calculations. I only want to remove the visible "0" text labels. Thank you for your help. |
| [2026-10-22 19:52:36] |
| John - SC Support - Posts: 48303 |
There is no option to not show the zero values. We have noted this as a Feature Request. We can not say when we would get to any particular request. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
