Date/Time: Thu, 22 Oct 2026 18:18:30 +0000
Step Trailing Stop moves the stop backward after a manual adjustment
View Count: 10
[2026-10-22 17:05:06]
n8trading - Posts: 84
Version: 2975 | Trade service: Teton | Order type: Step Trailing Stop (attached order)
Steps to reproduce:
1. Enter long [ES] at [5000.00] with an attached Step Trailing Stop: initial stop [4990.00], step amount [4.00], increment [4.00].
2. While price is at [5003.00], before any step has triggered, manually drag the stop to breakeven at [5000.00].
3. Price reaches [5004.00] and the first step triggers.
Expected: The stop stays at 5000.00 or moves above it. A trailing stop should never move to a worse price.
Actual: The stop moves to [4994.00], which is the original stop of 4990 plus one increment. The manual adjustment is ignored, and the stop is now 6 points below the breakeven level I set. The position has risk on it again even though I had
deliberately removed that risk.
Request: When a step triggers, the stop should never move in the unfavorable direction. For a long, the new stop should be the higher of the current stop price and the calculated step price (the lower of the two for a short). An alternative
would be to measure future steps from the stop's manually adjusted price. Either way, a manual adjustment should never be undone by the trailing logic.
Moving a step-trailed stop to breakeven is a very common way to manage a trade. Right now doing that is unsafe unless you also switch the stop to a plain stop.
