Date/Time: Thu, 22 Oct 2026 15:40:44 +0000
EUREX data
View Count: 26
[2026-10-22 14:48:56]
User210821 - Posts: 2
I payd for EUREX data feed, i have data but can not execute order EURSTOXX for example i am amp futures client and have teton data
[2026-10-22 15:11:32]
John - SC Support - Posts: 48296
Teton only supports trading with the CME Group.
If you want to trade EUREX with an AMP account, then you need to use CQG for your order routing for EUREX. As such, you can do one of two things:
1. Add a separate account with AMP to just trade EUREX with. In this case, you would want to install a second Sierra Chart, so you would have one connected to Teton and the other connected to CQG. Refer to the following:
Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart
2. Change your account with AMP to just use CQG for your order routing.
Keep in mind that Sierra Chart does not support data from CQG, so you will need to continue to get your data from our Denali Exchange Data Feed. Make sure you are not setup to also pay for data with CQG.
