Date/Time: Thu, 22 Oct 2026 14:55:01 +0000
Daily Charts Not Working
View Count: 26
| [2026-10-22 12:14:32] |
| User160573 - Posts: 3 |
Hello, Since I've activated the US Equities Consolidated Tape feed, I can't see the historical charts (1D) for several tickers anymore. Whenever I change the symbol, the chart will only show me the current day without historical data. The only ways to make it work are: 1. Edit >> Download Data For All Historical Charts; 2. By adding the '-NQTV' suffix to the symbol; How can I fix this? I want to be able to use the tickers as they are, without the suffix and the need to always re-download data. Thank you! |
| [2026-10-22 14:45:31] |
| John - SC Support - Posts: 48295 |
You should not have to do what you are doing. You should just get the historical data. What is "Global Settings >> Data/Trade Service Settings >> Common Settings >> Maximum Historical Days to Download for Historical Data" set to? And are you opening a new chart, or are you changing the symbol of an existing chart? What is one symbol for which you have seen this occur? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
