Date/Time: Thu, 22 Oct 2026 14:57:46 +0000
WEEKLY HIGH/LOW STUDY DISAPPERED UPGRADING TO VER 2976
View Count: 42
| [2026-10-22 11:43:40] |
| User60287 - Posts: 21 |
I HAVE BEEN USING THE WEEKLY HIGH/LOW STUDY FROM THE CUSTOM STUDIES AND IT HAS DISAPPEARED AFTER UPGRADE FROM VER.2957 TO VER.2976, PLEASE ADVISE
| [2026-10-22 13:18:32] |
| Sierra_Chart Engineering - Posts: 25243 |
This would mean that study is no longer available. This is the built-in study that you need to use: Previous/Period OHLC-Variable Period Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-10-22 13:22:01
