Date/Time: Tue, 20 Oct 2026 23:22:58 +0000
TAL results change after initial display
View Count: 32
| [2026-10-20 19:53:05] |
| walt_IB - Posts: 3 |
1. run a bar back test on 5 minute INTC 2. set date filter to include last 30 days and apply... 3. note the results 4. wait about 15-30 seconds then the results change significantly. The number of trades decrease (and the stats change accordingly) BUT all trades are still in the filtered date range, just fewer trades. This has happened on various symbols SOMETIMES ! >> I hate the word "sometimes"... Is this because the query has not completed? If so, that explains it; If not... >I did scour the docs and found nothing... |
| [2026-10-20 23:08:26] |
I found the trade service log which indicated that a query was in progress... > would be nice if nothing was displayed until the queries were completed. consider this closed... Thank You! |
| [2026-10-20 23:22:16] |
| Sierra_Chart Engineering - Posts: 25228 |
Most likely this is explained here: Trade Activity Log: Trade Activity Not Displaying or Clearing (Improving Trade Activity Query Performance) You are going to see the previous data until the query is completed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-10-20 23:22:50
