Date/Time: Tue, 20 Oct 2026 14:14:03 +0000
Αdditional questions
View Count: 30
| [2026-10-20 09:05:23] |
| User192420 - Posts: 2 |
4) I have prop-firm accounts that provide Rithmic data. If I connect Sierra Chart to Rithmic, can I download the historical CME tick data from Sierra’s historical servers with Package 3, without activating CME on Denali? 5) Do the historical tick records include Bid Volume / Ask Volume (trade aggressor side) for CME futures with Package 3, or is a higher package needed? 6) For US stocks: with Package 3, can I download historical tick data (with Bid/Ask Volume) without activating the US Equities or NASDAQ TotalView exchange on Denali? If an exchange is required, which one and what is the monthly cost for a non-professional? |
| [2026-10-20 13:47:44] |
| John - SC Support - Posts: 48265 |
4) No. You get the data from one source only - either Rithmic or Denali, not a mixture of both. 5) This information is included with the historical data. It does not depend on the package. 6) You do not need any special package to get the historical data, nor do you need an active exchange. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
