Date/Time: Tue, 20 Oct 2026 01:44:05 +0000
Large Volume Trade Indicator – marker size proportional to actual trade volume
View Count: 20
| [2026-10-19 23:28:39] |
| NikE3 - Posts: 1 |
Hi, Since updating from version 2789 to 2975, the marker sizes on the Large Volume Trade Indicator no longer show the difference in trade size in a usable way. Setup: - Version 2975, ESZ6 via Denali, 1500 Trades chart and a daily chart - Volume Threshold: 49 - Marker Color/Size Based On: All Loaded Chart Bars (Percentage Above Median 40 / Below Median 10) - Automatic marker size: min 15 / max 40 What I see: - All Loaded Chart Bars: almost every marker is drawn the same size. A 50, a 200 and a 500 lot look the same. As I understand it, sizing is based on the median ±%, with a 50% maximum, so anything above 1.5× the median is drawn at max size. - Visible Bars Only: sizes scale between the smallest and largest trade on screen, so one large trade flattens everything else. In today's session a 1000 lot made a 300 and a 50 look the same. - On 2789, with the same settings, the markers were clearly different sizes by trade volume. Question: Is there a way to make the marker size proportional to the actual trade volume, independent of the other trades that are loaded or visible? For example, a fixed scale where I set the volume that maps to max size (e.g. 500 lots = max size and everything in between scaled linearly), or size = volume × a factor. If this isn't possible on the current version, could it be added as an option under Marker Color/Size Based On? Before and after screenshots attached. Thanks, Nikos |
