Date/Time: Mon, 19 Oct 2026 19:27:17 +0000
1 side of DOM not populating
View Count: 41
[2026-10-19 15:49:52]
Lambrah - Posts: 2
Recently updated to the newest version of Sierra and only 1 side of the DOM is populating.
https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=144444
[2026-10-19 16:05:40]
John - SC Support - Posts: 48257
The "Sell" column that is showing data is definitely not an "Ask Size" column, as the data is not correct for that. Please check the columns you have setup and make sure they are what you are wanting.
If they are setup as you want, and you still do not get what you want, then please let us know what your columns are set to.
