Date/Time: Mon, 19 Oct 2026 00:56:47 +0000
submit a trade order from the Reward/Risk
View Count: 19
| [2026-10-18 23:24:15] |
| rededge - Posts: 2 |
when I submit trade order from the Reward/Risk tool. It sent market order instead limit order to match entry / stop / target 1. Order Confirmation showing correct, but when u confirm click yes, market order is sent (1.png) 2. u can see on 2.png order was placed as market order How to fix this |
| [2026-10-19 00:56:07] |
| Sierra_Chart Engineering - Posts: 25212 |
It is a limit order which can be seen in the order confirmation. What order type do you want to use? And a buy limit order, if it is above the current price, it will buy at the current price. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
