Date/Time: Sun, 18 Oct 2026 23:38:22 +0000
Custom DLL's and Version
View Count: 36
[2026-10-18 18:52:53]
User21113 - Posts: 63
Upgraded to latest version, v.2975. Created and successfully used custom dll's across many versions.
1. The custom dll's were successfully compiled using remote server: https://build2.sierrachart.com.
Open the Studies Dialog // Add Custom Studies... in the add study dialog the following is displayed...
example GroupIndices(GroupIndices_64.dll v.2969)
As Sierra Chart was upgraded to v.2975 the expectation is to see the dll displayed as v.2975.
example GroupIndices(GroupIndices_64.dll v.2975)
2. Is this the final version that requires recompiling?
Date Time Of Last Edit: 2026-10-18 18:53:21
[2026-10-18 18:58:25]
Sierra_Chart Engineering - Posts: 25211
1. The version you see is not the version of Sierra Chart that you are running when doing the build, instead the version within the header file, that you are using with the build. In this case it is 2969.
2. 2969 has the final changes.
