Date/Time: Fri, 16 Oct 2026 17:13:18 +0000
Ghost Study running
View Count: 25
| [2026-10-16 14:43:19] |
| Jaydtrade - Posts: 124 |
I created a custom study to play alert sounds when vpoc is pending shift. I removed it from chart and yet its still running and firing the sounds despite the study being remove and not listed on current active studies. How do I fix this?
| [2026-10-16 15:04:59] |
| John - SC Support - Posts: 48232 |
Although it should not be the case that the custom study is still running after being removed, restart Sierra Chart to ensure that there is not something occurring related to this. If you continue to have an issue after restarting Sierra Chart, then check your "Alert Manager" and see what it shows for the origin of that alert and determine what might be causing it based on that information. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
