Date/Time: Fri, 16 Oct 2026 02:23:38 +0000
moving average, bar time duration study
View Count: 20
[2026-10-15 23:20:46]
daif1029 - Posts: 15
hi, i had applied a moving avergae to the defualt bar time duration study.
what i am trying to formulate is the moving average being <= 00:00:02
[2026-10-16 00:38:32]
User719512 - Posts: 505
Bar Time Duration stores the time as a DateTime/double where the integer portion represents days and the fractional portion represents a fraction of a day.
You need to use the Spreadsheet Formula study or Study Subgraph Multiply study to convert the datetime into seconds; multiply by 86400 since there are 86400 seconds in a day.
Then you can use a moving average on this "number of seconds" study result.
Then you can alert, possibly with Color Bar Based on Alert Condition, when that value is under your threshold.
