Date/Time: Fri, 16 Oct 2026 02:21:02 +0000
Internal Number Precision Improvement Project
View Count: 34
| [2026-10-15 20:18:29] |
| FuturesBod - Posts: 31 |
Do you have documentation detailing what changed with which functions as a result of these improvements? I saw general comments like 'the main changes are' and 'we're going to change formats' but I can't find a reference style document that shows what changes could/should be made to what. I realize some custom studies simply need recompiling but I gather you've changed the types of some functions too. It would be nice to take the opportunity to review and ensure my custom studies are using the most recent data types. |
| [2026-10-16 01:26:31] |
| Sierra_Chart Engineering - Posts: 25192 |
Yes. All of that is documented on the What is New page here as changes are made: https://www.sierrachart.com/index.php?page=doc/Whats_New.php Every change is explained. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-10-16 01:26:45
