Date/Time: Sat, 21 Nov 2026 07:27:13 +0000
kwikpop replay
View Count: 2247
| [2014-11-08 19:49:53] |
| joer - Posts: 41 |
I am trying to replay a chart with Kwikpop studies. Even with Speed set to 100,000 it is taking about 5 minutes to replay 1 minute on the chart. I am using their new Dynamic Power Bars study. Are you aware of any problems like this?
| [2014-11-08 23:26:37] |
If you remove the custom studies, and you no longer have the slow replay time, then you need to let the developer of that study know so they can solve the problem. Refer to help topic 17 here: Http://www.sierrachart.com/index.php?page=doc/helpdetails17.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-11-09 00:17:44] |
We added help topic 17.5 which may be helpful for this problem: https://www.sierrachart.com/index.php?page=doc/helpdetails17.html#h17.5 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
