Date/Time: Wed, 14 Oct 2026 16:34:37 +0000
problem with copy trader
View Count: 22
| [2026-10-14 14:34:38] |
| rshahzad13 - Posts: 2 |
My copy trade is not working in Sierra charts anything I can do to fix it. It was working find till yesterday regards Rana |
| [2026-10-14 15:28:21] |
| John - SC Support - Posts: 48203 |
First, make sure the option for "Enable Order Allocation to Trade Accounts" is enabled (set to "Yes"). You can view this on your Trade Window for the chart by selecting the "M" button, then under "Settings". And check the following setting and make sure it is set how you want it: Global Trade Settings Windows: Disable Order Allocation To Trade Accounts on Chartbook Opening (Global Settings >> General Trade Settings >> General) Also, keep in mind that this is a "per chart" setting. So if you are using a different chart to enter your trades, you need to ensure that that chart has the "Order Allocation to Trade Accounts" setup. If everything appears to be setup properly, then after you enter a trade and if the orders are not copied to the other accounts then check your "Trade >> Trade Service Log" and see if there is any information in there regarding rejected orders for the other accounts. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
