Date/Time: Wed, 14 Oct 2026 00:12:51 +0000
Edit Files Window Requests
View Count: 43
[2026-10-13 20:33:59]
ForgivingComputers.com - Posts: 1241
Version 2971 has broken all of my custom studies, so I am busy rebuilding and uploading.
When adding or replacing files for automatic distribution, the Edit Files button that opens the Upload Files Window on https://www.sierrachart.com/UserControlPanel.php?page=SetFileGroupsForCustomStudies is different.
The Upload Files Window has been modified to word wrap and show 2 lines per file. Every time a new file is added, you need to page down or scroll down to the bottom of the window. I have close to 300 files, so this change makes it even more difficult to use.
Request 1. Can you fix the formatting, so the window can be adjusted, and the line wrap disabled?
Request 2: Also, it would be fantastic if this page could be sorted alphabetically by file name. It would make searching much easier.
Request 3: Can you place the Upload File part of the Window at the top instead of the bottom?
I was happy to see the Subgraph Drawing styles are now Alphabetical. These little things remove some of the platform's friction.
I know this doesn't impact the majority of users, but it makes the developer's job easier.
Thanks in advance.
Date Time Of Last Edit: 2026-10-13 20:35:22
[2026-10-13 21:22:20]
User719512 - Posts: 502
300...you are probably a big exception to the majority of use cases.
Something to try:
Use ctrl-F to find the study you want to manage.
Use ctrl-F for "cho" for "chosen" and it should scroll to the bottom where the buttons are.
...at least that might give you some relief while you recompile/rebuild.
[2026-10-13 22:49:46]
I am familiar with Ctrl-F. Thanks.
[2026-10-13 23:13:39]
Sierra Chart - Max - Posts: 5981
We have updated the page to loosen the width restrictions, which should remove the issue you are seeing related to multiple lines per file.
With the number of files, we do highly suggest the use of your browsers search function (CTRL+F).
Sierra Chart Support
