Date/Time: Tue, 13 Oct 2026 17:54:09 +0000
Background for Price Retracement Tool [Upgrade Request]
View Count: 15
[2026-10-13 16:45:58]
Deenius - Posts: 160
Would it be possible to add a background fill option between individual levels to the Price Retracement tool?
I would like to use this tool to display Premium and Discount zones, but unfortunately, this is not currently possible.
As price action traders, we typically apply the Price Retracement tool on higher timeframes and then switch to lower ones. The issue is that without a colored background between the levels, it is difficult to determine on lower timeframes whether the price is currently in a Premium or Discount zone. You have to compress the vertical scale every time to locate the tool's levels that help determine this.
However, with a colored background, it is immediately clear at a glance where the price is relative to the Price Retracement levels. This is clearly shown in the screenshots I have attached.
Thank you for considering my suggestion.
imagePremium - Discount - LTF.png / V - Attached On 2026-10-13 16:39:32 UTC - Size: 320.88 KB - 7 views
imagePremium - Discount - HTF.png / V - Attached On 2026-10-13 16:39:39 UTC - Size: 303.69 KB - 7 views
[2026-10-13 17:38:47]
John - SC Support - Posts: 48194
We have noted this as a Feature Request.
We can not say when we would get to any partucular request.
