Date/Time: Sun, 29 Nov 2026 14:31:52 +0000
2 drawing tool requests
View Count: 251
| [2026-10-13 16:10:14] |
| LittleBB - Posts: 19 |
Please consider these two requests: 1. Rectangle and Extended Rectangle Tools a. Please allow the Mid line to be displayed with a different color width and style from the outline. Reason: I get confused when the midline is the same color and style. 2. Arrow tool: Please allow the Drawing Tool Modifier Key to force a straight arrow. a. The line tool already does this properly. I found these undocumented settings and set them both to Shift. The arrow tool still won't remain straight as I move the mouse cursor. Drawing Tool Modifier Key for Snap to Angle {"Control", "Shift"} Drawing Tool Modifier Key for Snap to Bar OHLC {"Control", "Shift"} |
| [2026-10-13 17:06:14] |
We have noted these as Feature Requests. We can not say when we would get to any particular request. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
