Date/Time: Sun, 29 Nov 2026 14:31:50 +0000
CME non-professional data fees – is an AMP Futures account accepted? (Belgian resident)
View Count: 416
| [2026-10-12 20:29:43] |
| User698489 - Posts: 1 |
Hello, I am a Sierra Chart user (Service Package 11) residing in Belgium. I trade a Bulenox evaluator account via Rithmic Direct, so I do not qualify for CME non-professional fees through that account. I want to use the Denali Exchange Data Feed for real-time CME data (ES/MES). I am considering opening a live individual account with AMP Futures (using Teton Futures Order Routing), funded with the $100 minimum deposit, mainly to authorize CME non-professional data. Will an AMP Futures account funded with $100 be accepted as a live funded trading account for CME non-professional fees? If so, will Sierra Chart verify it automatically through Teton, or do I need to connect once a month? If AMP is not accepted, which broker do you recommend for a Belgian resident (for example Stage 5 with the Easy Solution)? Thank you for your help. |
| [2026-10-12 22:07:05] |
A live, funded account with AMP will qualify for the CME Group Non-Professional requirement.We can not answer whether $100.00 is enough for AMP. That is completely up to them. If so, will Sierra Chart verify it automatically through Teton, or do I need to connect once a month?
If you setup the account to be using Teton for your order routing, then you only need to connect the first time. From that point forward, we check your account through a back-end methodology, so you would not need to connect again.The above is only true for Teton, since that is our software. If you setup your AMP account to use CQG or Rithmic, then you will have to connect at least once a month for verification. If AMP is not accepted, which broker do you recommend for a Belgian resident (for example Stage 5 with the Easy Solution)?
Stage 5 is definitely the best option, as they tend to allow the opening of an account for $100.00. As noted in the "Easy Solution..." section, you can also try Stage 5 and Cannon Trading.
