Date/Time: Sun, 29 Nov 2026 14:31:53 +0000
Does Does the Denali Exchange Data Feed Include Order Book Depth Data
View Count: 270
| [2026-10-12 02:42:43] |
| User244102 - Posts: 1 |
Does the Denali Exchange Data Feed, CME Group, non-professional, with the market depth option, write every depth change to the .depth files in Data\MarketDepthData when Record Market Depth Data is on, for MNQ?” and “Which package is needed for that?
| [2026-10-13 15:08:04] |
| Sierra_Chart Engineering - Posts: 25523 |
The answer is yes, but it is not permitted to directly access the .depth files. Refer to the license agreement here: Sierra Chart License Agreement: DATA LICENSE Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
