Date/Time: Sun, 29 Nov 2026 14:31:51 +0000
Dom replay refresh rate is capped at 1 second, for market bid/ask
View Count: 367
| [2026-10-11 20:00:13] |
| sdarge - Posts: 4 |
I've set up DOM replay and downloaded the required market depth. I've set my global DOM refresh rate to 20ms and DOM perfectly matches that when not in replay. however, in replay mode, the limit orders refresh at 20ms, but the recent market bid/ask is stuck updating around once per second. I am on Service Package 5, how can i get tick data for the recent market bid/asks in replay? |
| [2026-10-11 20:34:46] |
| Sierra_Chart Engineering - Posts: 25523 |
Do you mean the Recent Bid Volume and Recent Ask Volume market data columns on the Chart DOM ? If market depth data, and trades are updating faster than one second, then those will as well. There really is not anything that can go wrong with this. We would have no suggestions about this at all.
| [2026-10-11 20:45:49] |
| sdarge - Posts: 4 |
ive uploaded a video. yes, i am referring to Recent Bid Volume / Recent Ask Volume market data columns. as you can see, they are "lagging" and updating once per second while the limit orders are updating very rapidly |
Private File |
| [2026-10-11 22:55:32] |
The Recent Bid Volume and Recent Ask Volume will only update when a trade occurs. They are independent of market depth data. Also check to make sure you are not using any volume filtering: Chart Settings: Volume Filter (Chart >> Chart Settings >> Data Limiting >> Volume Filter Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-10-11 22:55:47
| [2026-10-12 07:07:27] |
| sdarge - Posts: 4 |
is this a limitation of sierrachart delayed data? do i need denali datafeed to have better Recent Bid/Ask Volume. it does not update when trades occur, it updates once per second and skips all the data in between |
| [2026-10-12 07:32:20] |
No there is no limitation at all. Check these settings in Global Settings >> Chart DOM settings: "Recent Bid Volume Ask Volume" Display Both Last Traded Recent Bid and Ask Background: Reset Recent Bid/Ask Volume on Bid/Ask Change: Recent Bid Ask Volume Timeout in Milliseconds: 0 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-10-12 07:32:45
| [2026-10-12 19:12:57] |
| sdarge - Posts: 4 |
i've figured it out after digging for a few hours. it has to do with: Global Settings >> Data/Trade Service Settings >> Intraday Data Storage Time Unit Seirra automatically sets it to 1 second, hence the slow refreshing in replay mode. Replaying Charts: Chart Update Interval During Replays |
