Date/Time: Wed, 25 Nov 2026 06:49:30 +0000
ACSIL 2957: Capturing every completed live study update
View Count: 569
[2026-10-10 21:36:07]
User261096 - Posts: 3
On Sierra Chart 2957, can a same-chart ACSIL recorder, ordered after its referenced studies and using sc.GetStudyArrayUsingID, observe every completed live update of their latest-bar outputs before those outputs change again? We would use the documented calculation precedence and verify actual CalcOrder.
We understand that studies run sequentially at chart updates. This question concerns actual calculated study outputs, not hypothetical per-trade indicator values.
Can a referenced study’s latest-bar output change positive, then negative, then positive before the downstream recorder gets its turn, leaving the recorder with only the final positive value?
If this is possible, what supported mechanism captures those intermediate states or reliably identifies incomplete coverage? Please distinguish normal live updating from dependency-triggered recalculation, full recalculation, reload and replay.
This is a clarification of ACSIL scheduling and data access, not a request for custom programming.
[2026-10-10 22:20:06]
User719512 - Posts: 548
Check out:
Working with ACSIL Arrays and Understanding Looping: When the Study Function is Called
[2026-10-11 01:38:33]
Sierra_Chart Engineering - Posts: 25478
Yes inherently this will be the case. Using sc.GetStudyArrayUsingID makes sense.
No. As long as you get the values of another study on the same chart, every time your custom study is called, this is not going to happen.
[2026-11-03 06:53:36]
User374751 - Posts: 44
Does this apply to build 2781?
[2026-11-03 14:16:51]
It applies to all builds.
