Date/Time: Sun, 29 Nov 2026 03:50:25 +0000
ESR Future is not showing real time data
View Count: 221
| [2026-10-09 19:23:41] |
| User505908 - Posts: 2 |
Please confirm the supported SC Data/Denali symbol for December 2026 CME €STR futures. Investigate why ESRZ26-CME supplies historical records but reports live data unavailable, while SR3Z26-CME works. The issue is in the attachced file. |
Private File |
| [2026-10-09 19:57:49] |
ESR has nearly no trading. Refer to the following: https://www.cmegroup.com/markets/interest-rates/stirs/euro-short-term-rate.quotes.html Due to this, you will not see any intraday data. If you set your chart to Daily or higher, then you will see the data. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
