Date/Time: Tue, 24 Nov 2026 05:17:49 +0000
Deribit realtime data freezes randomly
View Count: 685
[2026-10-09 15:06:25]
User639867 - Posts: 59
Deribit realtime data freezes randomly throughout the day, but maybe especially when the market heats up. I noticed this on a much older version of SC and therefore upgraded to the latest version, but the same issue still exists. Disconnecting and reconnecting the data feed in SC usually fixes the issue.
I've only tested this on BTC-PERPETUAL-DBIT.
Is there anything you can do to fix this?
Date Time Of Last Edit: 2026-10-09 15:07:41
[2026-10-09 20:15:41]
Sierra_Chart Engineering - Posts: 25470
We would have to believe this has to do with the particular connection to Deribit and maybe their implementation of the FIX protocol. We are not sure.
Not sure we can make any improvement but we will look.
Date Time Of Last Edit: 2026-10-09 20:16:30
[2026-10-15 14:32:08]
In case this helps, it just happened again at 15:10 on BTC-PERPETUAL-DBIT when price action accelerated.
Disconnecting and reconnecting the data feed didn't help this time and the 1 minute chart froze for around 3 minutes and then randomly reconnected with a gap.
The data feed was showing as green and connected the whole time, but no new price data was received by any charts.
Deribit's native charts were fine throughout the freeze.
Any ideas about what might be causing this? Also, are there any SC settings that I could potentially change to stop this happening (as it is happening every day)?
[2026-10-16 13:27:46]
We do believe this is happening on the server side, but we are not sure why. Most likely it is a problem on the Deribit side. In which case there is not anything we can do to solve this.
In any case, there really is not much we can do right now.
[2026-10-16 13:38:28]
Okay, thanks. I guess I'll try contacting Deribit then. It just happened again at 14:31 for 3-4 minutes.
[2026-10-16 14:11:07]
Before you do this, let us make one change over the weekend and see if it helps.
[2026-10-19 14:53:20]
Data just froze again, and just in case this helps: the freeze only seems to be occurring when price action accelerates and hence *more* data is being recieved by the server.
Did you manage to make the change over the weekend?
Date Time Of Last Edit: 2026-10-19 15:03:07
[2026-10-19 18:28:13]
This must be a problem on the Deribit side.
There really was not much of a change we did. We just did a software update and restarted the process.
[2026-10-29 18:30:46]
Deribit support response:
Thank you for reaching out to Deribit Support.
While Sierra Chart is a platform partner, end-user client connectivity, local data buffering, and third-party software settings cannot be diagnosed or troubleshot by our support team.
For technical inquiries involving our integration, Sierra Chart's engineering and technical support teams have direct communication channels with our integration and API specialists.
If their team identifies a potential backend or API-level discrepancy on our side, they can liaise directly with our technical team with the necessary network/API logs.
Best regards,
Manu
It seems to me that it could be quick and easy to identify which side is at fault since if there is missing data on your side then the issue is with Deribit.
Any chance you can look into this further?
[2026-10-29 21:55:11]
We cannot spend any time on this now.
[2026-11-03 00:49:55]
No worries. I can understand why its low priority so I guess I'll just have to adjust to it for now until I find an alternative solution.
Maybe you should add a note to the following page so that potential subscribers know about the flaky data issue before purchasing a subscription:
Cryptocurrency / Bitcoin Data and Trading Services
Also, you need to remove BitMEX and FTX from that page since they no longer exist.
