Date/Time: Sun, 22 Nov 2026 22:21:00 +0000
Unknown SCID Open marker and quote-side allocation in US equity data
View Count: 476
| [2026-10-07 22:09:25] |
| Pintofj - Posts: 3 |
Our read-only SCID parser observes float32 Open=-1.999002852801023e+37, NumTrades=1, positive volume. This marker is absent from the IntradayRecord.h SDK we inspected. Can you confirm whether this represents a known odd-lot equity trade, and provide the authoritative definition and handling rules for price/volume profiles? In fixed historical windows, 493,946 unknown-marker records have volume below 100; SPY unknown records range 1–39 and recognized records start at 40, while the other sampled symbols split at 100. Is this marker related to the assigned round-lot threshold? Are it and High/Low/Close semantics affected by feed, historical adjustment, or chart settings? Example SPY 2026-06-30 18:21:34.117 UTC, source record index 42067087 (zero based): Open=-1.999002852801023e+37, High≈746.97, Low≈746.96, Close≈656.815, NumTrades=1, TotalVolume=38, BidVolume=38, AskVolume=0. We do not assume corruption or market-price eligibility. For documented single-trade markers, BidVolume/AskVolume are one-sided and coherent at distinguishable quotes, but many trades occur inside High/Low. What exact rule assigns their side? Does High/Low represent the contemporaneous NBBO or another quote source, and is there a historical event/receipt lag? Separately, all nine primary solar files have no SCID record at 2026-07-31 17:04:00–17:04:59.999999 UTC, while SPY/TAN have records and the IBKR archive shows positive volume for all nine. Please advise which technical acquisition evidence can distinguish a source gap from another cause without rewriting the history. No economic results, credentials or personal account information are included. We seek format and field semantics, not a trading recommendation. |
| [2026-10-09 16:47:08] |
| Sierra_Chart Engineering - Posts: 25461 |
For the meaning of that particular Intraday Record Open value, refer to: const float OPEN_VALUE_ODD_LOT_TRADE = -1.99900285e+37F;
const float OPEN_VALUE_FINRA_ALTERNATIVE_DISPLAY_FACILITY_TRADE = -1.99900298e+37F; These will be included in this file in the next release: \IntradayRecord.h The bid and ask prices with each trade, are the national best bid and offer at the time of the trade. The Bid Volume and Ask Volume are based on comparison to these bid and ask prices. We have no answer about this. There may have been a Data Feed interruption at that time: Separately, all nine primary solar files have no SCID record at 2026-07-31 17:04:00–17:04:59.999999 UTC, while SPY/TAN have records and the IBKR archive shows positive volume for all nine. Please advise which technical acquisition evidence can distinguish a source gap from another cause without rewriting the history. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-10-09 16:47:21
| [2026-10-10 13:02:42] |
Follow-up: historical SCID provenance, adjustments and personal offline research scope Thank you for identifying the odd-lot and FINRA ADF record markers in post 450713. We have kept odd-lot volume/count separate from trade-price construction. Before evaluating an offline statistical experiment, could you clarify: 1. For simple US equity symbols recorded in SCID while the trading service is Interactive Brokers and Sierra data-feed support is enabled, what Message Log entries identify the actual historical provider and downloaded date range? How should we document files containing historical backfill and later appended data from potentially different sources? We are not assuming the current connection proves the provider of old records. 2. For US equity historical SCID data supplied by Sierra, what is the treatment of stock splits, dividends and volume units? Can historical odd-lot markers/counts be reclassified during adjustment or redownload? Which logs or metadata can establish adjustments already applied to an existing file? We will preserve our frozen files and will not delete, repair or redownload them in place. 3. Please clarify the permitted scope for a single non-professional user's local, personal offline research on already downloaded historical SCID files. A local Python application reads files, creates local Parquet inventories and compares unsigned trade volume/count composition with historical price displacement. There is no redistribution, third-party money management or order submission. Does this particular historical/offline use require additional consent or a license? If so, who must grant it? Please distinguish it from processing live data or later automated order generation. This is a scope inquiry only; do not activate any service or charge the account. We understand that a general explanation cannot certify our specific files. Please identify the evidence needed to map provider, acquisition period and adjustments without altering the source data. We can provide technical file metadata and exported relevant log excerpts if required, without credentials. |
| [2026-10-12 14:42:54] |
| John - SC Support - Posts: 48610 |
Data in Sierra Chart can not be accessed outside of the system. You are not allowed to access the data directly from the .scid files. These are the rules from the exchanges for the type of data we get from them, and there is nothing you can get in order to be able to access the data within Sierra Chart outside of the program. The only option you would have is to get the data from a source that allows the kind of use you want. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-10-27 05:18:04] |
At this point we are declining further support. There are exchange policies, and the data cannot be used outside of Sierra Chart.
