Date/Time: Sat, 28 Nov 2026 03:04:42 +0000
v2966 sierrachart.h still uses define SC_DLL_VERSION 2964
View Count: 693
| [2026-10-07 20:29:20] |
| User719512 - Posts: 549 |
An oversight I am sure with the big refactor. FYI, recompiled all my custom studies and working fine in v2966. Software Name: Sierra Chart Version: 2966 64-bit Revision: 58577 As a side note, looking at scstructures.h struct s_ACSTrade void Clear(int StudyVersion) // For the StudyVersion parameter use SC_DLL_VERSION. would seem that the lines like: if (StudyVersion >= 2384) are no longer needed, and perhaps a refactor like sc_UseTool to use: unsigned int GetVersion() const might even be a better design pattern moving forward. |
| [2026-10-07 22:08:31] |
| Sierra_Chart Engineering - Posts: 25518 |
Thank you. We were already aware of this. We are working to resolve it.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-10-07 22:08:48
| [2026-10-08 07:23:41] |
Changes are now released. 2967.
| [2026-10-08 22:42:19] |
Confirming changes work great. Just updated to v2968 and it is great as well. In my humble opinion, these refactoring changes are very nice. Perfect opportunity for Sierra to take advantage for such things. I might be in the minority, but as a custom study developer a change like: typedef c_ArrayWrapper<t_ChartArrayDataType> SCFloatArray; ==> typedef c_ArrayWrapper<t_ChartArrayDataType> SCChartArray; // or SCDataArray, SCChartDataArray, etc. and all its related typedef cousins, would be a very simple change for me to adopt in my custom studies. One global find/replace would most likely fix any compile errors. To date, your thoughtful changes and rollouts have been very manageable. Appreciate all you do. |
| [2026-10-09 06:06:10] |
We will add this: typedef c_ArrayWrapper<t_ChartArrayDataType> SCChartArray; // or SCDataArray, SCChartDataArray, etc. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
