Date/Time: Sun, 22 Nov 2026 14:14:04 +0000
toggle chart window visibility from an ACS Control Bar button
View Count: 327
| [2026-10-07 14:56:02] |
| User845705 - Posts: 7 |
is there away to hide and unhide chart windows using the control bar and button?
| [2026-10-07 16:26:02] |
| John - SC Support - Posts: 48610 |
There is a built-in Control Bar button for "Hide Window". This is available under the section for "Window" in the Control Bar customization. There is no support for hiding/showing windows through ACSIL. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-10-07 16:35:29] |
Thank you, what I was looking for was the ability to have multiple buttons on a control bar that can bring up their referenced chart. For example a 60 minute chart say chart #2 that would be pulled up and then hidden after viewing it.
| [2026-10-07 17:05:06] |
There is not a way to do exactly what you want.
