Date/Time: Sun, 22 Nov 2026 14:14:02 +0000
Auto Coloring Based on Slope
View Count: 237
| [2026-10-07 13:12:25] |
| mkata - Posts: 104 |
Could you take a look at Auto-Coloring Based on Slope, I'm seeing some issues recently. To verify: If you take the 'Hi/Lo Over N-bar' study set to a fairly long length you will see the slope color change while the level remains unchanged. I'm on v.2957 |
| [2026-10-07 23:31:51] |
| Sierra_Chart Engineering - Posts: 25458 |
This is normal behavior we will make sure this is documented if not already. The look back number of bars is 100. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-10-07 23:47:02] |
A small code change was made and the documentation has been updated. This will be out in version 2967. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
