Date/Time: Sun, 22 Nov 2026 14:14:02 +0000
Repeated historical download failures — ESZ24-CME, Windows error 10053
View Count: 254
| [2026-10-06 18:23:00] |
| User444134 - Posts: 3 |
Hello, I am using Sierra Chart version 2957 with SC Data - All Services to download individual expired ES futures contracts at 1-tick resolution. ESZ24-CME historical downloads repeatedly disconnect, commonly after 39–40 seconds, with Windows error 10053 and “The network socket has been closed.” The attached log shows: Failures across ds28, ds32 and ds37 on ports 10149/10150. Repeated disconnections of the delayed data feed as well. Port 80 was tested: 96 requests received zero records. It has been disabled again. ESU24 previously received approximately 69.3 million records in one successful request. ESZ24 last recorded timestamp: 2024-07-24 09:40:11.200000. Historical download encryption was requested in settings, but the log does not show TLS/encryption confirmation. Could you review the log and recommend the next diagnostic step? Please also confirm how to verify that historical download encryption is active in this version. I need to preserve existing data and 1-tick resolution. |
| [2026-10-06 19:35:30] |
| Sierra_Chart Engineering - Posts: 25458 |
Are you using a wired Internet connection? Do not use a mobile connection. We see you are in Ecuador.
| [2026-10-06 20:20:34] |
Yes, Ecuador. Connected on Wifi.
| [2026-10-06 20:22:42] |
Would you like me to test the download using an Ethernet connection to the router and send you a new Message Log?
| [2026-10-06 22:06:54] |
| John - SC Support - Posts: 48610 |
Yes, please connect directly with a wired connection and see if you continue to have an issue. For the error 10053, refer to the following: Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem And we do not have a Message Log from you, either attached anywhere in this thread or sent to us through your account. Please get us your log after you try on a wired connection. We also recommend trying to connect through a different ISP and see if that resolves the issue. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
