Date/Time: Sat, 21 Nov 2026 00:42:11 +0000
Supported independent simulation-only cleanup and fresh state verification
View Count: 361
| [2026-10-06 14:04:25] |
| User408908 - Posts: 2 |
We are qualifying simulation-only timeout/restart cleanup in Trading Evaluator - Delayed, Sierra Chart 2915 / installed ACSIL interface 2911. No live broker is connected. Global/chart auto trading are OFF and local DTC Allow Trading is No. We reviewed ACSILTrading, TradeMenu (Trading Locked), DTCServer, WebAPI and ServerBasedProfitLossManagement. Required sequence: disable new client submissions -> cancel all working orders and confirm terminal state -> flatten/reconcile -> obtain fresh complete no-orders/flat account state -> engage Trading Locked and independently read it back. We understand Trading Locked blocks DTC submit/modify/cancel, so locking first cannot substitute for cleanup. A function return or cached empty view is not completion proof. 1. Does sc.FlattenPositionsAndCancelOrdersForTradeAccount work for an isolated Evaluator account with global/chart auto trading OFF? Does Trading Locked reject it? Which supported account-scoped sequence and completion/error notifications implement the ordering above? Is there a supported independent Allow Trading setter/readback or deadline lease, or should that setting remain a static precondition? 2. What supported mechanism protects this simulation account within a bounded deadline when Sierra desktop hangs, crashes or disconnects? Does server-based timed flatten cancel all working orders as well as flatten positions? What guarantees/limits apply to pending fills/cancels, rejection, repeated cleanup and restart? 3. Your WebAPI documentation asks us to contact support for the direct simulated-trading DTC address/port. Please identify the supported SIMULATION-ONLY endpoint, encoding and existing-access prerequisites for independent account/order/position snapshots and cleanup during desktop recovery. Which request IDs/end markers/reconnect rules prove a fresh complete account snapshot rather than a cached view? This is a technical documentation/capability question only. Do not enable access, change account permissions/services, add credit, place orders or incur charges on our behalf. No credentials, private exports, account identifiers or balance data are attached. If the required postconditions cannot be supported, please identify the precise limitation. |
| [2026-10-23 16:07:54] |
Hello Sierra Chart Support, I previously requested clarification regarding the permitted use of historical COMEX GC market data obtained through Sierra Chart, but I have not received a clear answer to this specific licensing question. I am developing a private, personal-use trading research application and already have historical GC data obtained through Sierra Chart. I would appreciate clarification on the following: 1. May I use my existing Sierra Chart historical GC data in a separate, local, offline Python program for feature engineering, machine-learning training, and backtesting? 2. If external Python processing is restricted, is equivalent private ML training permitted entirely inside Sierra Chart using ACSIL/C++? 3. Are additional CME exchange permissions or non-display data licenses required for either approach? 4. May I retain and use previously downloaded historical data, derived features, and trained model weights after my Sierra Chart service package expires? The research is strictly private. I do not intend to redistribute, resell, publish, or upload the market data to an external AI service. I am not requesting market data, account changes, trading access, or subscription activation. Could you please provide a clear answer with references to the applicable license clauses? Thank you for your assistance. |
| [2026-10-23 16:31:32] |
| John - SC Support - Posts: 48610 |
The first general statement that we need to make is that accessing the market data outside of Sierra Chart, or exporting it from the system in any way, is not permitted. Refer to the following: Sierra Chart License Agreement: DATA LICENSE 1. No. 2. Yes. 3. Not for using the data within Sierra Chart. 4. You can keep the exchange data that you already have within Sierra Chart and access it within Sierra Chart after your package expires. Any data that you derive from the exchange data that is not a duplication of the exchange data, or is a simple derivation of the exchange data that could be backward engineered to the original data, can be kept and used for your own purposes. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
