Date/Time: Sun, 22 Nov 2026 14:14:03 +0000
Trade DOM current traded ask volume bid volume difference volume bar - color issue
View Count: 295
| [2026-10-06 10:07:47] |
| EW trades - Posts: 5 |
Hi. I believe I found a minor issue. On the trade DOM column volume bars for "Current Traded Ask Volume Bid Volume Difference", there's an inconsistent mismatch of the coloring of the bars. I set positive numbers to blue and negative numbers to red for both text + volume bars. Notice the mismatch on some but not all price levels (ex. 064.50 which should be red or 055.00 which should be blue) I am using a 2 tick compression on this DOM (session volume profile with bid-ask difference volume bar coloring handles this w/o issues). I'm on the latest stable release using Denali data, NS what other info you may need. Best regards. https://www.sierrachart.com/image.php?Image=1791280975895.png Date Time Of Last Edit: 2026-10-06 12:02:56
| [2026-10-06 12:22:47] |
I did some more testing. The issue arises when Chart -> Market Depth -> "Market Depth Combine Increments in Ticks" is set to a number higher than 1. I had it set at 2 for a 2 tick compression.
| [2026-10-08 00:08:47] |
| Sierra_Chart Engineering - Posts: 25458 |
This will be solved in the next release. Thank you for letting us know.
